I am planning on building a 24x?? not sure on the depth quite yet and have never built one before. I have several questions and would like some opinions from others with experience so I will be asking several questions so I will start at the bottom of the building and work my way up. My first question is about scraping off the sod. Is it a must to take off the top layer or can I just set the posts and build walls then add 6" of rock/stone on top of the grass? Code in my area calls for 22" diameter holes and 11" thick under the posts. There has to be 48" of the post below finish grade sitting on the footings. I'd like to dig 48" deep holes, then add 6"rock after the poles are in and 6" concrete so i'd be good with depth of embedment. Does this sound ok to put rock on grass inside the building or is it a must to take off the grass and sod?
