New Product - Kera-Quartz™ Surface Sealer
LegacyIndustrial
deerfield, IL
Howdy Gang, it's been a minute!
Happy to announce a brand-new product made here in the USA, co-developed between Legacy Industrial Corp and our trusted partner.
Our Kera-Quartz™ is a (2) component, water-based, ceramic sealer. Kera-Quartz™ has a Hyper-Bond, it will adhere to glass and metal. In addition it features a high-wear additive that also increases COF for areas that might get slippery. Here are some popular surfaces we have beta tested: LVP Tile, VCT Tile, Porcelain Tile, Epoxy, Acrylic Sealers, polished/semi-polished concrete and terrazzo. (1) gallon covers over 1000 sqft. No smell, no fumes, 0% VOC, ships to all lower 48.
Here are a few pics, hopefully many more in the future!! Product link: https://www.legacyindustrial.co/products/kera-quartz-surface-sealer/
L
LegacyIndustrial
deerfield, IL
I have trouble believing the coverage. A gallon covers more than 1000 sq ft, really. That means the applied thickness is .0015" / one and a half thousandth of an inch or less.
It is a micro-coating and i mean micro!!
Strong but mighty. It’s not a meat and potatoes product, this is designed to help protect surfaces, or in some cases rejuvenate them. I put it on the fenders of my tractor and created a super strong patina!! The minimum application would be two coats over vinyl flooring, could be as many as five over polished concrete.
Hank11
Tennessee
This is coming at a good time for me. I have a new shop finishing up and would apply this over concrete that is about 12 months old. Would a scuff sanding with your sanding disks (that show up on the product page) be the appropriate prep?
As for the tinting, if I could get a non uniform whitewashed look I’d love that — a swirly mopped on look.
L
LegacyIndustrial
deerfield, IL
You would have to take it up to at least 200 grit using a heavy buffer or polisher. Our BonzaPad-Shine allows the user to buff the KeraQuartz to a higher sheen once applied. The actual polishing needs to be done with a hybrid polishing tool. 50/100/200 grits.
dcg9381
Austin, TX
Interestingly enough, we have two bathroom showers that are done is slate. I used @LegacyIndustrial polyurea on them before I handed them over to the tile guys and they turned out great... Have not re-coated them 3 years later.
This product would have been a lot less expensive. :)
