New Project - Mower Rebuild
BetterDays
I was given this old riding mower by a friend. Needs a battery, fluid flushed, and some repair as to why it won't roll easily. When in the air, the wheels turn freely (in opposite directions), but on the ground it will act as if it is locked in place. It sat for a while so I can only imagine what I may find....
Once repaired, I plan to sell it to purchase a lawn aerator. I only have a 1/4 acre so I can't justify a riding mower and could really use a lawn aerator.
Anyone have some information on this thing? Age, HP, where to get manual's if needed? Any advice on where to start?
ckal704
The code # on the engine will tell you exactly when the engine was built. Assuming the engine has not been replaced, that will give you a good age for the machine. From the picture it looks like the engine was mad in '73, but can't really tell what pat of the code number I am seeing. But the entire unit appears to be late 80's/ very early 90's vintage.
YYMMDDXXX (***=plant/line code)
I'd start by making sure the engine is sound. That is probably the most expensive part followed by the transmission. After that, it is nickel and dime stuff, but that too can add up.
spongerich
Monroe, NY
Hard to tell from the pics, but it looks like it's got a hydrostatic transmission.
I have an MTD like that and you can't push it unless you release the pressure. There's a little lever you slide, then roll it backwards a few inches and you should be able to move it.
BetterDays
Can you advise where this lever is? I may need to find it and solve mystery #1
:beer:
BetterDays
Unles you are wanting a project, or are a glutton for punishment, why not run an ad on craigslist to trade it as is for an areator?
I think it would be better to have it running than "not running, won't move, etc." ad on CL.
Aerators that I am looking at are around $400-$600. I know I will need to add to it, but I routinely see these units going for $250+ depending on condition.
spongerich
Monroe, NY
:beer:
Look for a rod/lever that connects to the transmission... If you can post some close ups of the controls, we might be able to figure out which one it might be.
NUTTSGT
Northern Central Ohio
I think that would only be if it was hydrostatic. That Toro hydrostatic kevin?
BetterDays
Not sure on the trans yet.
But, the brake was locked up. After removing the deck and searching around, found out that that the brake was not returning to its normal position (presumably due to being stretched out for a few years).
Planning to see if I can replace that spring tomorrow with something decent, washing her off (it was CAKED in grease and God knows what), changing the oil, buying a battery and seeing if she we will start and run...
Model #: 56127
Ser: 80062100
Amazing what happens when you spray two cans of BrakLeen at the beast....
PurdueSD
Indiana
Hah! we owned one of those groing up. Be careful on steep hills, the transmission will jump to neutral and take you for a quick ride. They ride like a brick with wheels, but cut grass just fine.
Oh fwiw. its a 5 speed manual with reverse. The lever is under the seat on the right.
ckal704
It is not a hydrostatic transmission, based on the foot controls I see.
Manufacturing costs of hydro have only come down low enough in the past several years to start appearing on the lighter homeowner equipment.
logical
Northern fringe of the Motor City Suburbs
Based on what I see the OP's Toro is not hydrostatic....but I was using a more conventional Toro lawn tractor to cut grass in Junior High School that was hydrostatic drive....and I'm 48.....so it is more than the past several years.
BetterDays
Model Number: 56127
Serial Number: 8006200
Product Name: 7-25 Rear Engine Rider
Hukd awn Fonikks didd know werk fer meye bruthah
BetterDays
I knew about the transmission lever. No matter where I moved the transmission lever, it wouldn't move...
ratdoggy
Akron-Canton area OH
Why not get it running and buy a tow behind aerator? I've seen them on the Northern site.
Once you use a ride-on you'll wonder why you didn't earlier. Of course your lawn has to be set up to use the ride-on. No low branches and not a lot of turns. I have an acre and I still need a push mower to get some areas.
BetterDays
This may seem stupid, but does the ****** have a neutral? Otherwise it'll only free wheel with the clutch in.
TheGrooveking
It has a neutral...
The brake locks up the chain sprocket for the chain drive which is why it could not move. I could lift the rear and spin the tires, but not move the chain.
BetterDays
Because my lot is only 88W x 144D.
It would take me longer with the tow behind than it would with the walk behind.
Not to mention, storage of the rider/attachment compared to a walk behind.
Oh, and I need the exercise. :lol_hitti
