TazioP3
All,
I bought a remanufactured compressor last year and finally got around to moving it this week. The thing was rebuilt by a pro, bolted to a new tank and got a new Quincey tank. It ought to work.
I had a service disconnect from my old compressor (30A) and I put a Siemens magnetic starter after that and wired things up like I thought they should be. The closed pressure switch completes the coil circuit and pulls the two pole switch shut so that 120+ volts is available through L1 and L2 to M1 and M2 (T1/T2?).
The four conductors (two big and two small gauge) coming from the side of the 5 HP Baldor L1410T are numbered an the pictogram suggests that the rotation is reversible. I matched the numbers according to the picture and connected each matched pair to a conductor (8ga) originating from M1 and M2. Thus, I believe I have 120V+#1+#5 joined by one blue wiring nut and 120V+#8+#4 joined by the other blue wiring nut.
Everything is grounded.
When the switch is closed, the mag starter snaps it's switches closed and the compressor motor buzzes but does not spin. I do this only momentarily, but in about four attempts, no breakers are tripped. I manually rotated the compressor's flywheel and watched the belts rotate the motor. There seem to be no physical restrictions, so I decided it was a wiring issue. Just for fun, I reversed the rotation (again following the pictogram). I also tried it with the smaller gauge wires disconnected. Killing time, I reversed L1 and L2. I flipped breakers off and on, added more grounds.
The best I can get is the low pitched, subtle, groaning buzz.
Any ideas? I am starting to get frustrated, a little...
Thanks,
Bill
Thanks,
Bill
