LOL...way to complicated for what it is!
I have a breaker panel that is for power distribution. Light and fan on one circuit, left side of building has 3 outlets (lamps and device charging. Right side of building has a circuit for small fridge and TV and vent fan. Also have one circuit for running a griddle or coffee pot. We usually a butane stove for cooking.
Now to explain how the power gets to the building. I have a 30 AMP RV cord that is wired to the L1 and L2 in the panel, and the neutral to the one bar, and I will put in a ground bar into the panel (it was not included in this panel).
I will run a 30AMP 110VAC to a pole with a RV panel (TT-30R NEMA). Same as what I plug my RV into at home. When power is available, I will plug my shed into this pole.
When I need to run off my generator, I will unplug from the RV panel power pole, and plug into the generator. Hence the "manual transfer switch" comment I made.
I have obtained the understanding I needed from the posts here. The only adjustment I need is to put in a grounding bar and separate the ground and neutral. 20 minutes at the panel. once I buy the parts.
