New shop build: air circulation
Gigemags05
Denton, TX
Hello,
I'm building an 18'x 35' shop. It will be insulated and I am putting an 18,000 btu mini split system in. The overhead door will be on one 18' side on front and the workbench area along the other in back. Located in the DFW area.
Questions:
1.) where should the inside ac unit be located? Was planning to install it on the back 18' wall opposite of the side of the overhead door above my workbench. Is this optimal?
2.) I currently have plans to install 4 outlets on a dedicated 20 amp circuit at 8' above finished floor. The plan is to mount some 20" oscillating fans to aid in air circulation. Will 4 fans be ok on that one circuit? Are four fans needed? Will it be too loud?
Thanks in advance.
JamesW84
Springfield, MO
Check how many amps each fan is, add them up and make sure cumulatively they are under 80% of the amp rating of the breaker (which is properly sized for the wire used).
As far as the mini split, when I installed mine in my house, the manual said to locate it where it would not blow on people, I assume for comfort.
Be aware, most mini-splits in A/C mode will create a "gym sock" odor if the interior set temperature isn't much lower than the outside temp. For example, if you set it to 70 degrees and the outside temp is 75, it probably will create an odor as it isn't working hard enough to get rid of the moisture (as I remember understanding it). However, if it's 80+ outside and you set it to 70, it has to work hard enough that there isn't an odor.
Mine created the odor, that's why I researched it and found that most units will when under a light AC Demand. Other than that, mine was great. I had a Mitsubishi GE24NA for my living room and loved it.
G
Gigemags05
Denton, TX
Hmm, interesting tid bit about the odor. Unfortunately, where I live, that little sucker is going to be working its tail off in the summer time haha.
I was searching for amp pull on some fans but haven't found any. I'll continue to look.
JamesW84
Springfield, MO
you can convert watts to amps if you know the voltage, which is probably 110. Just divide the watts by volts(convert kilowatts to total watts first, although I doubt they will use killowatts an hour).
So for example, a 500 watt fan would be
500w/110v=4.55 amps.
4 fans at 4.55 amps = 18.2 amps, which would be too much for your 20 amp circuit. Obviously, that's just an example.
Lets find out the most watts your fans could pull:
20 amps * .8 load = 16 amps
16 amps/4 fans=4 amps per fan.
4 amps*110v=440 watts.
You need a fan that pulls less than 440 watts (or 4 amps per fan) if you want all of them on the same circuit. I'd say that should be easily attainable.
G
Gigemags05
Denton, TX
Looks like the wattage for most of these fans is well below 440, mostly in the 150-175 watt range.
Anyone have any recommendations for a good, quiet oscillating fan?
