As already mentioned, stainless sinks normally come with clips that fold down under the cutout lip (and then tightened)
If you haven't got any, just use some clear silicon. Run a bead under the sink lip then install the sink - you can weight it down with a few bricks etc.
I also then run another bead around the outside of the lip to make sure no moisture will get in and damage the benchtop.
Clean up any excess silicon using a spray bottle with a mix of water/dishwashing detergent. Just spray it around the lip and on your finger and wipe around the lip. As you go, wipe the excess silicon off your finger onto a piece of scrap cardboard or whatever and keep re wetting your finger.
Hope this helps.
Regards Scoots (contract cabinetmaker/installer
