New Snap-On IM6100 1/2" Impact Wrench
TXSTGLIDE
Liberty Hill, TX
$200 plus $10.00 Shipping
Brand new without box IM6100 1/2" Impact Wrench. This impact has never even had an air ****** installed. It comes with the RCR "Richard Childress Racing" cover with it. It has the comfort grip handle that allows for less fatigue when using the tool. It also has the lever that allows you to bypass the exhaust system for increased torque. I purchased 2 of these a few years back and never wound up needing this one. I'm still using the other one at this time.
The below specs are pulled from an outside website. While I believe them to be correct, I do not guarantee or represent them.
IM6100 Features
• 8-vane air motor provides faster motor start up and greater low torque output. • Reverse valve increases sealing surface and improves air management.
• New muffler by-pass detent maintains exhaust position during heavy impacting.
• Stronger valve spring prevents accidental movement of FORWARD/REVERSE lever.
• Made in USA.
Patented Cushion Grip
• Field replaceable.
• Ergonomically designed for the best hand fit.
• Provides vibration and thermal isolation to help prevent operator fatigue.
• Ribbed for positive tool control.
Cushion Grip Trigger
• Rounded comfort corners.
• No pinch points.
• “Soft Touch” featherability.
• Patented tip valve design for greater control.
Patented Power Boost Muffler Bypass System
• Valve allows exhaust to be vented through the handle (closed) or above the trigger (open) for maximum performance.
• New detent maintains selected operation.
• Quiet operation in closed mode.
• Made in the USA.
Product Specifications
Stock # IM6100
Price** $369.00
Square Drive, inches 1/2
Recommended Air Pressure, psig (kPa) 90 (620)
Air Consumption, free speed, cfm (scfm) [l/min] 5.3 (38) [150.1]
Air Consumption, working, cfm (scfm) [l/min] 4.2 (30) [118.9]
Free Speed, Forward, rpm 8,500
Free Speed, Reverse, rpm 8,500
Sound Level, free speed, dBa 103
Sound Level, working, dBa 92
Blows per Minute 1,300
Maximum Torque, ft. lb. (N•m) 575 (780) Forward, 650 (882) Reverse
Air Inlet Thread Size 1/4"-18 NPT
Recommended Hose Size, inches (mm) 3/8" (10) ID min.
Overall Length, inches (mm) 7.95 (201.9)
Height, inches (mm) 7.95 (201.9)
Vinyl Boot YA980
Width, inches (mm) 2.67 (67.8)
Weight, lbs. (kg) 6.7 (3.04)
iajonesy
Iowa
Saw them being made last night on the tube on HOW IT'S MADE. They are made in Canada.
Mike
dieselmike
BC
not everything on how its made is made in canada. these are not made in canada. the impacts on that episode are the MG 725.
