New SO 100 Gear tooth ratchet?!
a3tripod
wouldn't more teeth in the same size head imply narrower/weaker teeth? Will this handle as much torque as the 72 tooth predecessor?
rsanter
visalia ca
if they make the teeth smaller then yes each tooth will be able to carry less laod. to compensate they will spread the load over more teeth so they can have the same or better load handeling
bob
29Sedanman
Indianapolis
I dont think the high tooth count looses any strength. Just like in a rear axle. A stock axle I believe is usually a 28 spline. If you buy a high performance axle from Strange or someone it will probably be a 31 spline or so. Like said above, it is simply spreading the load.
Rocket1
Arlington, TX
I have the 72 tooth version and I love it. Its probably my favorite ratchet especially when I work on my Trans AM because I don't bust knuckles trying to reach the back spark plug on the pass side. I think I will have to pick this one up soon.
wellstig1
Torrance, Ca
I have one of these and I love it. If your fh747 were to be "broken" this would be the replacement and you wouldn't have to pay a dime
D
DavidtheDuke
The rebuild kit for this 100th might work just fine in the last generation's head as well. Worth asking a dealer about.
Deafautotech
Indianapolis, Indiana
i have a Fh747 but my snap on guy said it can't interchange the heads... i was little depression as i love the black hard handle... oh well i use a lot both round head and 80teeth ratchets... i tried to use air ratchet but most of time i am work in tight area...
gofastman
Minnesota
just pull off the hard handle and press it on the new ratchet
speed bump
Butte Montana
Since no one can tell the differance the previous model is 49 teeth looky here. Also for those thinking that a rebuild kit might do something magical for that old FH747 NO IT WILL NOT. why you ask? Because the teeth in a round tooth ratchet are part of the head and the pawl is in the center.
My only question is when is the quarter drive version coming?
superautobacs
Vancouver, BC
:+1: Speed Bump knows....
Unlike a traditional ratchet design, when the teeth get worn out, you end up having to replace the whole handle/head.
06wt
chicago 434 UNION CARPENTER
mrshaun
so i have a F748 with a fresh rebuild kit in it and it still slips, so im in for a new 100 tooth or can i get the 49 tooth head housing. Cuz its a long handle rotator with the standard handle wich i like, id rather not have the comfort grip, but it would be nice to have a 100 tooth
walrus
Maine
When I go to check out with the new 100 tooth it says its in stock now. Merry Christmas to me:bounce:
autobody
Minnesota
I have been waiting 2 weeks for mine from my Snappy truck guy, so we will see if it comes this coming week.
kwhitelaw
i've had mine for a month and still havent had a need to use it :(
maybe i should take something apart just for the hell of it lol...
kwhitelaw
you got it but never use it?? it is something wrong...:headscrat
no, i just dont wrench anymore. my SO guy knew i wanted one, hell he didnt even know it was coming out til i told him.. he snagged it for me last month but i have had nothing to work on so it sits. no biggie
Deafautotech
oh, all right... i can't wait for mine to arrive so i can use it as i need smaller swing arc because ford engineers keep it make more crowds and tight area!!!!:wtf:
