So I have been trying to upgrade the space recently....Recapping I added the garage thinking I would be able to put the workable space and new electrical hookup in the addition. The footprint was limited and I had a lift come my way that just fit so I grabbed it. Kids in college and job changes took a toll but suffice it to say things are getting much better.
I have began the massive cleanout by plucking bins off the shelf on the weekends and filling the trash cans. I also began a new 10 hour work days with a 4 day work week. Things were starting to progress nicely, Insert COVID comment here. BAM now everybody is home and Fridays are not just mine anymore.....but went to a rotational weird schedule at work because of said disease and found myself with ten days off....what to do?
I hated not having bench space and to complicate things more the refreshment cooler was located on top of my bench because of one electrical outlet on this side of the garage. It was not a good situation. I did some research and found on the outer wall next to my tool box was a outlet in my dining room. it is not used very often so I though i could tap into it and create the needed hookup to make it happen.
Garages in my area have to have GFCI breakers for code and even though I am not pulling permits i do want it to be proper. So after a trip to pick up material, i had a GFCI outlet for my 20 amp circuit. Let the fun begin.
[/url][/IMG]
So the fun part was figuring out the line and load tie in because this was part of a run and i was cutting in on the middle of it. I am ok at electrical but not my strong point.
[/url][/IMG]
After that was relocating the fridge from the old bench location. Previous cluster F%^k
[/url][/IMG]
Also wanted to mount the newly inspired drill holder/ charging station that i had built. I put this together using a circular saw and clamps on a level for straight line cuts. I make do with what i have.
[/url][/IMG]
I then moved on to mounting a fused extension outlet on top of the drill holder and mounting it on the wall. Plugged in and ready to go.
[/url][/IMG]
Fridge was defrosted and reloaded:
[/url][/IMG]
Bench pegboard extended and relocating of tools has began. Still sorting through all the stuff so i can find things. It is mind numbing the amount of things i have collected over the years.
[/url][/IMG]
[/url][/IMG]
So the end goal is to get better access to tools and more workable space.....for what? I have not one but 2 Triumph TR3's waiting for work. I have started categorizing all the parts and cleaning what I can. Back to it a little at a time:
[/url][/IMG]
More to follow and i hope you can follow along....it is good to be back.
JP''
