new special equipment trailer build any tips ?
sweetk30
finger lakes area upstate ,ny
so i am ready to build the new equipment trailer for the season coming up soon .
this is a driveway / parking lot sealer rig with all equipment .
here is 2 ruff ideas for the trailer frame and layout of equipment .
there will be a 550 gal sealer tank over the 2 axles so this area is already used up . then the last 4 ft of the trailer is a equipment storage platform/tilt down gate ramp combo for the hot tar unit on wheels and the driveway blower . there will be no rear tail cross member since there is this back there .
the front half will be a hot tar propane fired unit on the right front area . then 4 20lb propane tanks securely clamped in to a center post unit with forklift tank clamps . next is another 4 holder unit for the empty 5 gal sealer buckets we use for moving product . there will be a few pegs for up to 50 road cones storage . using 18" cones over the much taller units as we just need to block traffic flow to drive ways is all .
between the front area and BIG tank there will be 1 or 2 pickup truck tool boxes for tools / equipment / gas can storage / caution tape / all this stuff . plan is to drop them in on top of the frame rails to keep it low and easy to get to unless i should put them up on top .
then the bulk storage area will be for 30lb boxes of hot tar product to be used in the tar machines . plan is to keep this low and possible expanded metal on the bottom of the frame rails to create a 5" deep storage area and the floor on the bottom .
the frame layout i have has a big A-frame tongue setup with a 2-5/16" ball coupler . then a center point back to the front cross member or even further back to the 2nd cross member . the A-frame will be below the main platform layout of the whole trailer .
the suspension will be tandem leaf springs eye to eye style springs and equalizer bar in the middle . the springs will be for 14k lbs total capacity . the axles i will be doing 2 7klb 8 lug axles both with brakes . tires and wheels will be 4klb per unit and 12 ply or 14 ply tires trailer special for a good firm sidewall and less flex .
knowing all this is there any tips ? tricks ? or changes you would do for the trailer build for strength and or life span of the trailer ?
the tank will hold up to 6,600 lbs of liquid sealer at 1 time when full from the bulk buyer . the hot tar product in the 30 lbs boxes will be qty of 15-20 boxes at a time max . there will be a 15 gal water tank in the middle for hand washing and or rinsing stuff off . there will be a few hundred lbs of sand and small chip stone for small crack bulk filler and or hole filler .
thanks for any help and tips .
Pics 1 & 2 planned layout
Pic 3 is blower and tar buggy the way they will be on the back gate unit .
Pic 4 hot tar unit right front
Pic 5 - 7 is basic layout with old boat trailer i am using for layout before i build the real trailer .
matt_i
I would make it a gooseneck :) Would tow much easier with a 14k gvw...
What do you use to tow it, a K30?
I use an R30, while an impressive gas guzzler it gets the job done even after 32 years.
sweetk30
Bumper pull for this will be fine for our use . Its a 3 county use trailer only so it never does much highway or long hauls .
That would be a good idea tho . Might just half to think it over .
Would i be ok with the size tube i have on order to make the goose neck ?
This new trailer will be much bigger and better than old so i am on the hunt for a c/r-30 . But i got a possible line on a 01 or 02 3500hd 15k gvw 1.5ton with 8.1 vortec . Got to go check it out .
APEowner
Sunny, New Mexico
Think about where the lights, license plate and spare tire are going to live early in the design process. Those are all items that end up being in the way and/or broken off on a regular basis if they're not carefully integrated in the design.
Monza Harry
Windsor ON
+1 Make that +10 to the 2nd power! Spare consider if you even need it, wheel /tire weigh in at #50 + and then the mount and the jack and it will rot out in front of your eyes unless this trailer lives out it's life indoors. I added the licence plate mount into my rear "bumper(?)" rearmost crossmember of my latest [ongoing] trailer project and I will not likely be carrying a spare, weight is an issue on this one, small truck and a car on said trailer.
Harry
sweetk30
thanks guys . :bowdown:
i know all to well about the lights and plates . fixed lots of them for people over the years .
spare tire not going to as tow rig will be same 8 lug and its a local only trailer so if need be steel it from truck .
tongue jack is a top wind CURT rated at 8k max capacity :rocker: . NOT a cheepy off brand 2,500 lb unit . :sad:
sweetk30
Just got back from picking up my 4x10 sheets ( qry-4 ) these will be my floor area thats open and the rear platform ramp area .
