New Stiletto TiBone 3 hammer
snickers muncher
Northeast GA
I just got in a 15 oz. TiBone 3 Milled Face Curved Handle hammer. I haven't seen them anywhere else, so I thought I'd a few pics real quick. The second generation had a problem with the head coming loose and they claim to have solved it. There's a wedge washer under the bolt head and the nail groove is deeper than the previous version. Here it is next to a steel 22 oz hammer and with a 12p nail in it. I didn't have a 16p handy. It's definitely longer and lighter than I'm used to.
alinc100
Dearborn,MI
About 8-9 years ago I was working on a large refinery scaffold project and the TBII was the preferred hammer of choice. I was buying them on Ebay through this reseller. They've went up a bit ,we were getting them for $162-$165 delivered. Over the course of two years I ordered almost $3K worth. I made a $1 or $2 on each one ,plus did a card raffle @$5 card/$5 for $20 and paid for my hammer that way.Otherwise I probably wouldn't own one. It is a great hammer,but my current project is better suited to a 12 oz trim hammer.
https://www.ebay.com/itm/NEW-STILET...938612?hash=item48d22ef734:g:G9gAAOSwNiNZp8Rk
dutchgray
Dorset. England.
I have 2 TBII but actually use the Vaughan Douglas pattern titanium when I am not using a steel hammer, though the screws that hold the handle on like to come loose on it.
Is it still made in the USA?
snickers muncher
Northeast GA
Yeah, the teeth sure will bite. It should do a real number on your thumb.
Yes, it is still made in USA. I think only the solid titanium hammers are USA. The titanium heads are made in China on the rest. I can just barely see some teeth on the two washers so maybe they'll hold and not loosen up.
The magnet is quite strong and holds well.
daween
Kansas
I got one too. I tried to replace my milled face with a smooth one, but I couldn’t remove the head, even with a Milwaukee impact wrench. Have you tried to remove the face yet?
snickers muncher
Northeast GA
No, I haven't tried to remove the face. I think they are torqued to around 35 ft/lbs, so an allen wrench and a short pipe is how I would attempt it.
Everyone is amazed by how light it is when they pick it up.
mobiledynamics
Gotham City
I know lot's like the TI.....but in past reviews, one wrong whack = breakage. Sure it's lightweight, and may allow you to swing harder. But for 2 bones +.....and brittle, I dunno . Have looked/considered them many a times
usdemt
South Dakota
Is there a reason they make the head and handle two separate parts? They are both Ti correct?
Instead of buying two expensive hammers you can swap the head from a waffle face to a smooth face. So for the guys that do it all, frame the house with a waffle face, then move into sheetrock, trim areas.
snickers muncher
Northeast GA
The face is steel. Titanium is fine for relatively soft nails, but use with rebar or harder steels takes a toll on the titanium faced hammers. The idea is that the replaceable steel face makes it suitable for framing and concrete form work as well as giving a milled/smooth choice.
