New Table Saw/Welding Table
mark8040
I don't post much but I get an awful lot of inspiration from the stuff that you guys are willing to share! Thought I would try and pay it back a bit...
I'm in the process of moving out of a larger shop that I've rented for several years back into a two car garage at my home. I had a full size Delta table saw that worked great for the projects I've worked on. I hated the idea of giving up my table saw but I really don't have any space to bring it home and I've never had a dedicated welding table. I bought a 3'x4' Certiflat table and poking around the inter-toobs I saw several examples of wooden worktables with job-site table saws that were built in. I decided to try and combine the two. What could possibly go wrong with this idea...
I had to pretty much gut the Makita to get it down to something I could work with. I've done a few projects on it so far and pretty pleased with how it's turned out. Absolutely love the Certiflat table and the saw fence is just as accurate as the one on my big Delta.
Threw in a picture of the cheap Amazon lighting I put in first. These definitely solved my lighting problem, super bright.
Vertical legs are 3" square, the two at the end where the receivers are welded on are thick-wall, all the rest thin-wall. Horizontal pieces are 2" thin-wall that I had a stack of. Table top is 3/4" MDF that's doubled up on the perimeter and along the center supports. Bunch of wipe-on poly thinned with mineral spirits in an attempt to keep it looking nice. Orange 5 gal bucket has a Dust Topper on it, still need to finish up plumbing the intake side. We'll see how effective it is for dust collection from the saw. Yellow extension cord coiled up on the side of the table is to power the saw and the plugs mounted around the table. Finished off the steel with Smoke Gray Rustoleum rattle can.
Not sure about the weight but it's pretty hefty. Not hard to move around with a good solid shove. I have a covered carport in front of the garage. Looking forward to rolling it outside to work when the weather is nice. I'm done with the poser photos, now it's time to beat it up!
Hopefully someone will see something they can use on a project! Feel free to criticize, I have tough skin!
VOH
New Braunfels, TX
Thats great looking! my only fear would be the possible pitting from grinders / cut off wheels on the MDF and saw.
lis2323
Awesome design and fabrication, mark. [emoji106][emoji106]
Attention to detail is outstanding.
tarbellb
Oregon
Looks real nice, lots of great details. Super clean.
Ill say it too tho.... I would keep that MDF and table saw covered during welding. Unless you only TIG? You will definitely get pitting and burns from MIG welding.
mark8040
Thanks everyone! Ever had one of those projects that you thought would take you a couple of days to knock out and you're still working on it two weeks later?? Yea, me neither...
There's no doubt the MDF will get marked up from welding/grinding and everything else I'll end up doing to it. I look at that work surface as being sacrificial, something that can be easily replaced if it gets too bad. As long as the MDF stays flat relative to the Certiflat table, the burn marks, scratches, dents etc. really doesn't bother me, I consider them wounds of battle!!
I'll share the goofy project I'm working on now with you guys when I get it done. You know, in a couple of days or two weeks...
slowtwitch73
Hellgate
Very good.
I am finishing out a new shop now and a table like that is on my shortlist. Will be using a similar Bosch saw.
What kind of fence is that?Doesn't look like it came with that saw.
Renegade1LI
long island ny
Welding and saw dust doesn't sound like a great idea.:headscrat
It ***** with a small shop & you do a little of everything. If I weld inside I do a good cleaning, then open the garage doors & blow it.
I like the table, the welding side is set up real nice.
mark8040
mark8040
I hear you guys loud and clear about the sawdust. Most of the time I do a pretty good job cleaning up between tasks but I have to admit, I've welded once or twice standing on a pretty good pile of sawdust without an issue. But I have had my share of problems with rags soaked with mineral spirits on a couple of occasions! I like to sand off my project metal and wipe it down with mineral spirits before I start most projects. Keeps me and the project cleaner that way. More than once I've forgotten to throw the rags out of the way before welding and ended up with a small fire at the end of the workbench! Hell, I've even caught a glove on fire because I got mineral spirits on it right before welding! Safety third...
