New to forum. Planning Garage Project
slickgt1
Hi All. I'm new to the forum. Been hanging out here for a while, lurking, reading. Finally ready to renovate my garage in NYC, Brooklyn NY to be specific.
My garage is basically under my house, and takes up about 40% of the entire lot/basement. Not too big, but anywhere to park is better than looking for a spot for 2 hours every night.
The size is about 18.5' by about 20' - 25'.
I need some advise first.
I want to do tile floor. One thing I have always wondered is if I can put electric radiant floor heating under the tile. I have installed it before on renovation jobs, but never in a garage. So I am curious if anyone has done that, and which manufacturer to you recommend.
I also want to have about 4 spotlights under the car area. I just need some light that I can flick on with a switch for when I need to be under it. Anything you guys can recommend? I guess it needs to be safe to drive over and such.
I also would like to run air to the 4 corners of the garage so that I won't need to have a 50' air hose from the compressor. I am thinking of doing that out of gas piping. I though about going the plastic kit route, but I would like to make sure that if I ever go to hand something on the wall, that I don't puncture anything.
My current ceiling is metal sheets. Probably fire code back in the day. I plan to remove all that and replace with fire rated Sheetrock. I need to open it anyway so that I can insulate, as my tenants living room is right above the garage.
I should have pictures up soon to show what it looks like so far, and my progress. Thank you all in advance.
Stuart in MN
Minneapolis
Electric radiant floor heat is generally low powered - it's used mainly in bathrooms, and is just enough to keep the floor warm on your bare feet. It probably wouldn't be enough to heat a garage in cold weather. There have been a couple discussions on floor lighting in the past, here are a couple of them:
http://www.garagejournal.com/forum/showthread.php?t=13907
http://www.garagejournal.com/forum/showthread.php?t=1419
For the air lines, if you mean PVC pipe that's a no no for compressed air. There are a jillion posts here on air lines, if you do a search you should be able to find some good information.
slickgt1
Hi Stuart,
Thanks for the reply. No I don't want the radiant floor to actually heat the garage. I want it mostly to keep the moisture off the floor, and get some warmth if I need it when under the car, or sitting on the floor by the bike. My garage is fairly warm in the winter. I have a massive steam line going through it, and it never dropped below 68 deg last winter. My main concern is will the weight of the car/bike damage the radiant floor? I don't think it will since the flooring usually gets a skim coat of cement/thinset before tiling, but you guys might have more experience in this area.
I forgot to ask you all another question. My concrete is cracked in a few places. Do you guys recommend I rip out those sections and re-cement it? I doesn't seem to move, but I don't want to take chances especially with tile going on it. I think I answered my own question.
My concrete slab also looks like it might have been painted at one point or another. Do I need to sand it or something before tile will stick to it? Is there a primer product, or some acid that I can do. I would like to avoid acid, as my tenants live right above the garage, and I live above them.
thanks again.
