Todd.Brock
I found a Champion. The model is hard to read but it's a VRV5-8. ( I think). New in 1996. It was used until a few months ago when it was replaced for a higher CFM unit. Owner replaced all the reed valves, plates and gaskets last summer and the motor in 2008. The motor is the "down" side if their is one. Its a 3450 RPM AO Smith. Per Champions website, the pump puts out about 16.5 CFM at 175 and 20 CFM at 100psi. It spins about 770 rpm. If you put a 7.5 horse motor it speeds up to about 990 rpm and 25CFM. It was bought new, used in the same corner with an auto drain for its entire life until it was swapped out. He has all the Gardner Denver receipts and invoices for the intake plates and valves from last summer. He even kept a maintenance log. It has a few gaps, but its the only person I have met that keeps a log. The guy runs an aluminum wheel refinishing business. He said it was used daily, but works fine. I said its essentially going to the retirement home. I won't use it a 10th of he did. Anyway, paid $625. My IR is going on CL this week if a guy who wanted to buy it doesn't come through.
