New to me champion Compressor
an0nymous
Any thoughts would be appreciated.
Think maybe the pulley on the motor is too small, but that's conjecture.
CNGsaves
KS and OK
Couple questions . . . . where'd you get it?? How much??
Also, why does that motor tag have Chinese on it??
zkling
Can you post the RPM of the motor and the diameter of the pulleys? That way we can calculate the pump RPM and see what it is currently running. I can't clearly read the motor tag in that pic, does look like a Chinese motor though.
It's an older, small output champion compressor, single stage, but a well built unit. Looks to be pressure lubricated.
A
an0nymous
Crigslist.
300$ from an asked 500. Not sure if good or not,
Beats me. The motors dated 77. Replacement for a 3 phase maybe? I've only owned it a day.
Here's a higher res tag photo:
I'll have to post pulley diameter later.
A
an0nymous
smaller pulley diameter (electirical motor)seems to be 3.25 inches +/- .25
Big Pulley (compressor) is 18 inches.
zkling
With a 3.25" motor pulley, a 18" compressor pulley and a 1740RPM motor, you are getting ~314RPM at the pump crank. Which is pretty low. Now I am not real familiar with those old Champion pumps, but usually the older pressure lubed pumps run about 600-800 RPM. Which would be correct it that motor was 3450RPM. Does it pump up and run good? Did you try it before you bought it?
Maybe give champion a call and see what they can tell you about that model of pump.
A
an0nymous
Thanks for the input. Saw it run.
Seemed like it ran a bit slow, but very quiet.
zkling
What is the model number on the pump? I can't read it in the first pic. Something like 5E, 8E, SE?
How many drive belts does it have? Hard to see in the pics.
A
an0nymous
How big a deal would it be to up the smaller pulley size? Or is that not how it works?
GoodoleBoy
Thats a Jap motor..Excellent quality stuff..
