reverendjonas
- Joined
- Apr 8, 2009
- Messages
- 16
Hello guys,
Im pretty new around these parts, but have read enough to see that there are many knowledgeable people around these parts, and was hoping someone can help me out. Anyway...
I just purchased my first house, and was pleased the previous owners left me this old Speedaire compressor next to the shed on the side of the house. I should start out saying, I am a compressor newbie. I have only had oil less smaller compressors before so I know nothing. I have poked around google for a few days trying to find info on this compressor, as far as size of tank, cfm of pump etc, and have not come up with anything. So I have a few questions.
For starters, where do you drain the oil from? And what is the best oil to replace with? It works now and pumps up to 160 psi. From what the pressure switch says on it it is 145-175. Is there a setting inside to adjust this? What is the easiest way to drain the water from a horizontal tank? I have always had vertical tank compressors and they were easy with the drain in the middle bottom. Maybe the easiest thing to do is to post some pics and a vid and if you all wouldn't mind, just tell me what you see there
Thanks in advance for any info given.
Here it is in auction.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/0Z6lEDrYaB0&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/0Z6lEDrYaB0&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
more pics to come
more pics to come
) You are correct that it seems much more quiet than the other compressors I have. Even if it is not, the sound of the lower rpm motor and pump is much more pleasing on the ears than the screaming of the oil less.
