shoot summ
- Joined
- Jun 8, 2010
- Messages
- 2,974
I've been helping a Neighbor sell off her deceased Husband's tools, had a huge sale last weekend and alot of stuff cleared out. I did snag a Puma 60 gallon upright compressor for $200.
I got the compressor home last weekend and have spent the week going through it cleaning it up. He had it sitting outside under the soffit of his shop so it was a bit dirty but overall it is in good condition. There was a drain valve set up on the tank and it appears he drained it regularly.
Here is what I have done so far:
1) Replace drain valve and pipe with brass pipe and ball valve
2) Replace mismatched intake filter assembly(I found the original broken housing in his shop), I noticed the cheap replacement he used was much louder than the factory filters.
3) Pull all of the fitting off the tank and clean the threads and reseal everything.
4) Change the compressor oil.
5) Clean up the wiring.
6) Add a ball valve to shut off the air.
I fired it up last night, it is still a bit louder than I want, but MUCH better than my Crapsman 33 gallon oilless. I'm considering the Solberg intake silencers but am wondering if I really get $75(3x$25) worth of silencing out of them?
The other thing I was trying to achieve, and maybe I am chasing a dream here, is a tank that would hold the air pressure over time. I found one small leak last night in the drain valve assembly and fixed it. When I shut down last night the gauge was at 130lbs, this morning it is around 110lbs. Do any of you guys have tanks that hold their pressure over time, or should I just expect a small leak, accept it, and move on?
