freudianfloyd
I have been doing fabrication for the past several years, but most of my experience is with welding and the lathe. I am trying to get a hang of using a mill but have been having some issues.
First off the "mill" I am using is a Jet JMD-15 so I know it is limited in what it can do.
I am trying to mill down a 3/4" parting tool holder to fit in my 5/8" tool post. I first tried using a 3/4" endmill with a .125" depth cut, but the machine was making all kinds of noise so I backed off. The material is cold rolled by the way.
I switched to a 3/8" endmill to make multiple passes, and it worked if I made really shallow cuts, but after I made a couple, the start of my cuts were lower than the end of my cuts, and the first pass was lower than my second. Basically every cut was making a stair step. Is there something I am doing wrong, is it a limitation of the machine? The part I was milling was firmly in the vise on a set of parallels. Is it possible the end mill is sliding inside the collet?
Any advice would be appreciated.
Also, I was running a 3/8" roughing end mill at around 300rpm and feeding it manually.
