I'm in Canadistan so no HF here. I'd posted a couple threads looking for help on tool selection and in the end went in an unexpected direction, but basically followed a lot of advice that said to get a big set to start.
I was planning on getting Williams 3/8" sockets/wrenches, gearwrench 120xp ratchets, and sunex 1/2" impacts along with a couple other things to start but I ended getting almost everything from Canadian Tire. The prices and discounts were simply too good to ignore. Almost everything I purchased was 50-70% off yesterday so I made off like a bandit.
I got:
Overall I saved hundreds of dollars even off regular CT prices.
Mastercraft 400 piece set
I basically got this since this would allow me to cover every size in both SAE and metric. There's some waste in here as far as I'm concerned. Does anyone ever use spline sockets? I'd have rather had proper deep/short sockets in the more common sizes...
The sockets are ok. They're laser etched. All standard depth. No deep/shallow except on spline sockets which have a bunch of deep for whatever reason. I can immediately see why people prefer stamped. The latter is much easier to read. And the etching isn't in consistent place on sockets. I put them on socket rails for now and sometimes the number is completely hidden. Socket quality itself is OK. I've felt some fit well and others a little sloppy but I just got the set yesterday so limited use so far... I can see myself acquiring deep/shallow Williams sockets sets for 3/8 and 1/4" but not right away. Can live with these for now.
The wrenches are pretty lousy. Very thin beams. laser etched markings. Set has gaps. No equivalent of FD+ on the open ends. I'm going to go ahead and buy the Williams MWS-15A (7-21mm) set immediately, but the mastercraft can serve as extras or if/when I need two wrenches of same size...
The ratchets are useable but not great. I can see myself getting the gearwrench 120xp set or some used snap-on f80 style ratchets in the near future. Handles are kinda short on the mastercraft ratchets. Not a huge fan of reverse mechanism and they're not flex ratchets, but they work. No idea how much torque they can take yet...
Maximum 1/2 and 3/8 drive Torque Wrenches + 1/2 breaker bar
These I'm very happy with. They're well made. I was originally planning on getting split beam Precision Instruments torque wrenches, but given 50 and 66% off I got on these two wrenches, I'm very happy with them. No plans to replace. The breaker bar is really solid too.
Misc
Magnetic pan. Everyone should have one. So useful.
Lastly, I didn't bother with impact wrench. A good Milwaukee electric one capable of 1100lb-ft breakaway torque is $500 up here (the tool-only one is only 700lb-ft). At this point, I don't feel I need one. Once I get to point where I'm doing suspension work and need really high torque I'll probably get something but it's total overkill for removing lug nuts and that's all I have to do for now.
Summary
It's hard to go wrong for $200 CAD. I've now got all my bases covered. That said, the wrenches ****. I'll still be ordering the 15-piece Williams set in metric. The sockets seem hit and miss so far. Again, I'm probably going to end up with Williams in shallow/deep sooner rather than later. Will probably get snap-on or gearwrench flex head ratchets too. Even with what little I've done I can see the benefit of a flex head, longer handle, and better ratcheting mechanism.
The Maximum breaker bar and torque wrenches are great though. I'd still go with the precision instruments at full price, but if you're Canadian and see these on sale for 50-70% off, they're a definite win.
Lastly, a note on Maximum vs Mastercraft sockets. Frankly, I didn't see a huge difference though I had trouble comparing 1 to 1 of equal sizes because they were in locked display case. But the Maximum sockets are still etched and not stamped.
Also, all of the Mastercraft and Maximum stuff is lifetime warranty, so easy to exchange anything that breaks. So the big set was good to start with, but even as a newbie I can already see reasons to upgrade parts of it. That said, my mind has already been infected by GJ and I have the sickness now...
I got:
- 400 piece socket/ratchet/wrench/allen key/torx/hex/spline in 1/4, 3/8 and 1/2" drives for $199 down from $750.
- CT "Pro" brand (Maximum) torque wrenches in 3/8 (50-250 in-lbs) and 1/2 (50-250 ft-lbs). for 50-66% off each, $49 and $79.
- "pro" 1/2" breaker bar for $12 (down from $45).
- 9 piece wobble extension set (with mix of 1/2, 3/8, and 1/4 drive) for $9 (down from 45)
- other bits and pieces including jack and jack stands, grease gun and grease, magnetic pan, etc
Misc
Summary
