New Type of A/C-Heat
red vette mike
Madison, Ms
My friend has a 3 car garage. He just bought a a/c-heat unit. The unit has a real thin outside compressor unit that feeds into a wall mounted inside unit. It has no tubing or duct work. He said that these have been used in Europe for years. It is doing a good job on cooling this space. The best part was the cosst-around $1000. I just spent $3900 for a a/c-heat heat pump for my 31x54 garage. I wish I had known about this setup. Any of you good folks familiar with this type of system? I will get the name of the system from my friend and post it here.
Mike
cw_racefan
Yep, looking into one for my garage. They're referred to as mini-split or ductless heat pumps. There are a few threads floating around here on them. The a/c only type are very popular in the Caribbean. Lots of different manufacturers out there. I've seen anywhere from 3/4 ton up to 2 1/2 tion units. Seems like a great option to me.
Craig
JMURiz
NoVA
Great idea, they might be cheaper than the hotel-style units I was thinking of using in my garage. I suppose a 1-ton unit would be good for a 2-car garage.
cw_racefan
Not sure about cheaper, but one thing I like is only one small hole in the wall for the refrig. lines. I had looked into the hotel type ones also. As far as sizing, I had one place recommend a 2 ton unit for my 32x36.
BoostAddiction
Western North Carolina
The Garagenous Zone has a mini-split. I selected it because I would need no new ducting, it was very quiet and the most efficient unit I could find.
It was also much cheaper than the conventional heat pump solution.
Obligatory pic:
-Will
Scott12v
Pittsburgh, PA
Yep...that's exactly what I've been looking at too. The mini-split systems seems to be the best bet for a garage that you can't put a window unit in.
JMURiz
NoVA
Will, what brand did you go with? I also like the ability to have heat, a window AC unit can't do that for ya.
BoostAddiction
Mine is a Daikin. Made in Japan, just be reintroduced to the US market. I got it at Smarter Way in TX. I don't think there are many places where you can buy them.
As an indicator of how efficient they are, I saw the same unit in a solar home on the national mall at the last solar decathalon; those guys live and die on efficiency.
-Will
BoCRon
Alpharetta GA USA
I'm going to go with a small PTAC unit. We have installed 3 larger PTAC units in our kennel/training building and they are fabulous. The best way to center a unit in my garage means the unit is fairly visible from the walkway to the front door, so I'm trying to get a smaller unit. My garage is only 490 sf, so a small unit should be fine. I also have a small side storage room that we are setting up as a grilling kitchen for my husbands grill, I will add a small wall unit for heat in that room, cooling shouldn't be too big of a deal.
Here's a link to the PTAC units. I'm going with the 26" Amana for my garage, I have the full size units in the kennel. They are heat-pumps.
http://www.valleyofsun.com/store.tpl?rnd=298&cart=BA9F922D-96E5-4D3C-97A4-914A76ACF243&
Here is what I'll add to the small side room.
http://www.eheat.com/data/products.php?opt=products&show=0604
Oh, and I love this site!
Annette
JohnZ
Washington, Michigan
04 Navi said:
Say where did you find a 3.5 ton? Biggest I've seen is a 2t. Thanks. BTW I want to use it to heat/cool a 36x40x9 garage/
I found it digging around on-line 18 months ago. I originally planned on a Carrier mini-split system they advertised, but found out from the local contractor I selected that they weren't making them yet (and wouldn't for another six months); he suggested the Mitsubishi system as an alternative (he handles both brands), and the bonus was that the Mitsubishi system was available in the 42,000-BTU size, vs. the (not available) 36,000-BTU Carrier system. His crew installed it in about six hours and it's worked flawlessly ever since - just finished its second summer of keeping me comfy instead of sweaty and crabby. :thumbup:
:beer:
