colinfindlay
- Joined
- Jul 13, 2014
- Messages
- 1
Hi,
I'm about to embark on an epic garage flooring mission, and need a bit of advice.
I've looked at a lot of options for the floor, a 50sqm new slab - and so far VCT has come out a clear winner in terms of price and function. I'd like porcelain but the final cost is a couple of thousand dollars more - as I don't think I can DIY install the tiles, but VCT seems quite a bit more idiot-proof.
However - as I'm from New Zealand, a lot of the materials available to me are different, so it's a bit tricky to compare to what you guys in the States have tried & proven.
I'm going to use Armstrong Excelon Black VCT tiles - the Aussie ones are more or less the same as American ones. However, for adhesive I have been recommended Armstrong PS-820 - is anyone able to comment on how this might compare to S-750?
I also have the following Polyurethane recommended as a coating to go over it (Dulux MaxiProof) - it seems reasonable, and I believe some people locally have used it over commercial vinyl without issue - any idea if this will bind to sanded VCT without epoxy? (Which is proving impossible to find something that's been tried before)
C
C
