New Water line-1/2" or 3/4"
jessieh2
I have a 1/2" water line feeding my workshop. I currently have a toilet and sink at one end of shop. I would like to extend the line to opposite end of shop (75') and place a water spicket on outside. I will be using PEX with pipe insulation and run thru the attic. Should I use 1/2" to extend with or would it help my water volume to use 3/4"?
The Cobbler
75' is a long way for 1/2" . lots of friction loss. What is the flow like now with the 1/2" ? sink and toilet may have ok flow, but will the spigot? might consider running new 3/4 the entire way
jumpstart
Central MA
If you are just extending the 1/2" feeding the shop, changing to 3/4" isn't going to change anything since the feed is still 1/2". 1/2" is fine for the extension.
ducksface
Use the 3/4
The half is too frictiony
The volume is what your current half inch regulates.
The new line will add friction.
If you have the little black
Ref book
It's all in there as to line size and elbow restriction percentages.
davewo
USA
I have a 60'-ish long run of 1/2" PEX to an exterior hose bib and it flows just fine for a yard hose.
