joshmodelskidoo
Got a Campbell housefield 100amp 115 volt welder years ago and I struggled to weld good. If you lay down a ft of weld then probably 1-2in would look good with Lincoln flux core wire. Put a new clamp on it and that was much better, now it welds good 95% of the time. I used a century a few years ago and it worked great as a mig but I don’t recall if it was 110 or 220 volt, I only laid down 3-4in of weld when i was helping a guy out using his welder. Got some gift cards and cash for Christmas so I picked up a hobart handler 190 220 volt only and wow!!! What a difference. The Campbell housefield i had to keep the wire speed from 3/4 to 1.25 and this hobart i set it where it said (believe 6 wire speed)and it was fantastic, actually sounded like a wire feed welder. I also ordered an Amazon Chinesium special called a bestarc. That’s the first plasma cutter i ever used. I just tried it out on some 1/8in steel and it cuts like butter. Way better than a 4.5in cut off wheel. I tried to cut the thin part of a railroad track(1/2in probably) and it didn’t get it done but maybe i went to fast? Using it on 220 volt but it can be used on regular 115/110 for the thinner stuff.
