New welder
My2boys
Edmond, OK
My wife gave me to go ahead finally to get a new welder. I have been reading a lot about them. I think I have narrowed it down to three first the millermatic 190, lincoln 180, and the hobart handler 190. I wanted to see what everyone thought, and if you have one of these what made you choose the one you purchased.
Thanks
Ryf
Southern Ohio
I went with the Hobart handler 190, brother in law went with the lincoln 180C (theres three versions of the lincoln) both are great IMO, we both hobby weld a fair bit, and both machines work well as intended. I went with the Hobart because its a great brand at a fair price. I really liked it has the spool gun setup pre wired, but if you know you might want that or know you need it, you might as well get the 190 that has it. I also like Tractor supply has the consumables for it, which is close to the house and open later than the welding supply (lowes is about 15 mins farther out for very little lincoln stuff available). hobart and miller share torch parts which is good.
he went with the lincoln because its a great welder and he's owned one other lincoln and it served him well as well. if your looking, the 180C is the version you get from a welding supply, it has the aluminum/metal wire guide housing, there are also two price point versions (weld pak and pro mig) that have fiberplastic drive housing, as well as some other small differences. know which you are looking at, and spend accordingly :) most of the 180c's have it on the front under the knobs, the price points have their marks at the top center.
I can't comment on the Miller, but they have an excellent reputation as well...
I would go with what you can get consumables for locally when you'll need them, nothing ***** like loosing your pace for some project when you can't get welding tips, etc after 5pm. would be nice if there was an authorized repair facility locally too, just in case, but we havent needed them... knock on wood!
with the three brands listed I have few doubts you'll be happy with your choice. good luck choosing!
zkling
What do you plan to do with the machine and what is your budget? If you don't mind my asking. I assume you mean the miller 180 vs lincoln 180 vs hobart 190. I am a miller / hobart person. Not a fan of Lincoln's current offerings.
Tricon
Southern California
Not to hijack, but would it be absolutely crazy to start with a TIG inverter? I really want to weld aluminum and titanium for hobby, moto type stuff. No can do with a MIG right?
zkling
Correct, tig is the most versatile, but usually the most expensive to get into. If you would like to discuss this more please start your own thread to be fair to My2boys.
BD1
north side
johnny5c
+1 on the Millermatic 211. I have a MM250 in my shop and needed something portable so went with the 211. The infinite controls make it great for auto body sheet metal plus will still do 3/8" on a single pass.
brownbagg
they, all three are quality machines, but the 110v machines are really only good for sheetmetal. get into the 220v machine for a good uniform welder.
as far as starting off with tig, nothing wrong with that, same answer, the 220 v machine are way better in what they can do over the 110 machines.
malibu101
Walnutport PA
Welding machines are a case of bigger is better.
You can adjust a big machine down, BUT, you can't adjust a small machine up beyond its limits.
Even if you only see yourself doing small, thin stuff now. You WILL find yourself wanting/needing to do thicker stuff soon after you have a machine.
I have a Miller 180 MIG and a Miller AC/DC buzzbox. The stick takes over where the little MIG lets off. It works for what I do.
I would love to have a TIG bit can not justify one for my personal hobby uses.
71goldss
Northern Calif
+2 on the Miller 211. Bought mine a few months ago on the Miller rebate program. I've never welded a thing in my life, and this thing is so easy to set up and use, it nearly makes me look like a pro! I did a lot of "reviews" and "how to" forum reading and watched YouTube videos before buying mine, and everything pointed to the 211. I would purchase again in a heartbeat!
