I have design, fabricated and tested a tool for cutting windshields. I done this after trying the typical methods (root-zip with diamond bit, die grinder with diamond blade and sand blasting). After performing the previous methods I felt it was a huge gamble to use one of them on a new windshield so I designed the new one. I have tried several complex cuts (name in cursive, parallel cuts within 1/8" of each other) and extreme scenarios (no water at fast cut rate) with the new tool and have not been able to make the windshield crack. The tool will cut the entire length of windshield in less then 10 minutes.
My question is - how many shops/individuals would be interested in buying a tool like this if it was in the $500-1000 range (all USA components and high quality build). Just trying to decide what I should do with this tool.
