The time has come! I have been putting off building my dream garage for years, lack of time main problem.. I never seem to be able to hire anybody and tend to do everything myself from start to finish. I am out of room at the house and my other shop is accross town.
I can not decide what the perfect size or material , block, steel, or stick?
My first plan was a 60x60 with 3/12 pitch steel building, block 48'' on the front and sides. 40 x60 will be main shop area with 20 x60 loft and wash bay with equipment rooms , utility ,wash shower room.
In floor heat with a out door furnace , well and 500 gal septic also.
My question is if I use decorative block or brick 48' then hardibacker siding to match a cedar home, would you bother with a steel building type structure or just stick build?
My main reason for the steel is the clearspan, and seamless steel roof. Things I do not like about the steel is the 3/12 vs a 6/12 pitch.The insulation method for them , (hanging from the ceiling or walls) The engineer recommends a conventional footer in our area and block at least 12-18'' from the ground , so either way I have the cost of footer foundation with steel or stick. In the end steel may cost as much as a stick structure or be equal. Solid block is out , my other shop is 3600 sq ft block and is hard to heat and expensive. (old porcelin brick gas station with block addition)
Open for sugestions,
Thanks ,
Macdabs
Thanks ,
Macdabs
