NewAge system question
Lost me beer
Micky Town
Cant find this in all of the other NewAge posts, so please bear with me.
I am about to order 2 sets of NewAge Bold 3.0 8 piece system. Going to mount them to the wall with the 4 tall cabinets on the ends.
First off. Where should I put my outlet box? (Wiring garage now) Not sure where the power strip wire can run without interfering with the mount when on the wall. Is there a channel or something? Should I just put the outlet behind the cabinets? Or below, beside???
Second, how does the wood worktable attach? Do they have to attach to the tall cabinets? Or can they mount to any of the other smaller cabinets? Obviosly not to the roller boxes. Confused.
Thanks for any insite.
Troy
dittle fart around
Vancouver, Washington, USA
Troy, check out my website ShopStorageCabinets.com and wander around. Check out the videos.Each of the different styles has a video and at the bottom of each page is a link to more videos.
The base cabinets all have grommeted holes in the bottom for cables to run.
The next question is do you want to cut a hole in the back of the cabinet to line up with the wall outlet, where ever you put it. This won't affect the strength of the cabinet, unless you get carried away and cut the back off all the way.
Once you have power in one base cabinet you now have access to all of them. Drill a hole and put grommets between the tall locker cabinet and the wall cabinets for under cabinet lighting. If you are using corded tools on the worktop, bet it would be nice to have an outlet above the worktop height. There are some nice plug strips that mount over a electrical box. Get one with circuit breaker and your good to go.
Check out the installation instructions , you'll have to download this as it's a pdf file. You'll also find what comes with the cabinets, NewAge is pretty good about supplying the appropriate hardware. You can mount worktops directly to the cabinets and the lockers have angle brackets to support the worktops without a cabinet underneath.
L
Lost me beer
Micky Town
That helps a lot, ty.
I will go over thise installation instructions soon, but I am still unsure how the table attaches...must it attach to a tall cabinet? Seems every pic I see is this way. I want to attach 1 side to a lower cabinet...
Troy
dittle fart around
The worktops mount directly to the base cabinets. If you want to leave a space for a stool or whatever, you need to support the end of the worktop. If you are planning on having base, empty, base, and are using 56" wide base cabinets, use the bracket in the tall locker on the base cabinet to support the end of the worktop that is floating in space. Sounds like that might be the plan?
