mamasmeat
Hi there and thanks for reading.
I'm almost at the stage of applying my epoxy to a 2-car garage.
I swept first, vacuumed, power washed, power washed with a mild soap, then power washed again.
I acid etched with citric acid, and I just filled my contraction joints with foam backer rods & Legacy Industrial's gel crack filler.
I am preparing to grind the gel filler smooth with a diamond cup wheel attachment.
Here are my questions. How long should I wait for the filler to harden/cure before grinding? Additionally, since the grinding will no doubt knock up some concrete dust as well, what should I do to clean the floor before applying the epoxy?
Also. In a corner of my garage is a platform for my hot water heater and a small metal pole to keep people from backing into it I presume. My plan WAS to just apply the epoxy up to the edges of these (pics included) and then do a simple caulk or apply the gel around the edges and then use a regular color-matched paint to blend it in.
Since I acid etched about 2 or 3 days ago, reading some of the previous posts here has me kind of paranoid about the pores sealing back up with dust and whatnot, so I was thinking maybe I should just say screw it and grind the whole thing instead and then wash it one or two last times?
Couple pictures included.
Thanks for any of your input.
-Ryan
-Ryan
