Hi all,
I just picked up a hydraulic press (basic 12 ton HF version, nothing fancy), and already I have a question. This is probably screaming obvious, but I can't seem to get my head around it.
I have a 1/2" mild steel rod, 24" long and threaded 1/2-13 on one end. On the other end, I'd like to press on a 2" long stub with a blind hole, 1” diameter (1/2" hole for the press fit).
How do I go about this without bending the long rod (and/or sending it flying)? I figure if I drop the platen of the press low enough to fit the whole 2ft length of rod in, the rod will just bend before the press fit happens.
Thanks for any pointers you can give,
Lee
Sent from my SM-N920T using Tapatalk
Lee
