cooljw
I am a new homeowner and have begun prepping my garage for epoxy. I already bought 2 kits (4 gallons total) of the Rustoleum Epoxy Shield Professional (solvent based) from Home Depot. Are people satisfied with this stuff? I have ~525 s.f. of garage floor to cover.
After hours of research online about how to do the job right, I finally found this board - what a great place! Now I understand that floor prep is 98% of the job.
I have a few prepping questions I could use input on:
1.) It's a new home (very clean concrete) and yes the concrete has already cured for 5+ months. I did not clean/degrease the concrete or use any floor grinders/sanders. Is this OK?
2.) Yesterday I used muriatic acid solution and did the whole acid, scrub, rinse, scrub, rinse, squeegee routine. Is there a way to tell if my floor is ready to be epoxied now? Should I use a de-acidifying treatment before proceeding?
3.) I have concrete "curbs" at the bottom of my walls and I was planning on epoxying these surfaces too. However, I did not acid etch these surfaces because they touch the drywall and are elevated. Plus, the concrete here is a very rough finish, almost like a popcorn ceiling. Will that alone hold the epoxy OK or should I prep these surfaces somehow?
All the horror stories about epoxy jobs flaking and lifting are scaring the **** outta me, so I want to make sure I prep correctly.
