Hi guys,
I have been lurking for a few years here but just registered.
I have just bought my first house. A 3 bedroom single story with 7.8ac and a 32x24x12 (approx) pole barn. I live in northern Ontario and the barn has heaved quite a bit (18" in the worst part). The house inspector said the frost depth is about 6' so I doubt the posts are down that far.
I don't know of any way to get the posts back down. So I am thinking of disassembling the barn and doing proper concrete footings to put the posts on. The posts are 6x6 PT, there is a steel roof, engineered trusses, and true 2"x6" girts.
I would like to save the posts, girts, trusses, and tin on the roof. I want to put the barn back up in the same spot and possible add 8' to the length and probably bring the eave down to 10' high.
6' is a long way into the ground!
My plan is to get 7' holes dug, add 12" gravel, and 2-3' of cement as a footing. I will then place the post on this footing (3-4' of wood in the ground depending on how deep I go with concrete) and back fill with gravel or cement. Does that sound like a good way of doing things?
