Next little resto, nothing fancy HDP125
gilbo
well i picked up my next little resto project, nothing crazy, just a Delta Homecraft 11-120 drill press. its in pretty rough shape.
maybe original motor ??? but looks like toast
Any tips would be greatly appreciated, here are a few pics
bl00
Chantilly, Virginia
Got the same drill press sitting on the floor. Take lots of pics please, so I can refer to them if I ever get around to refurbing mine. :)
G
gilbo
Nice find. I'm looking for a nice old drill press to restore myself. Whats the plan for it?
nothing fancy just a simple resto
the drill press parts itself is done, debadged,ran through electrolysis, wire wheeled, primed and painted already
still need to polish up the column,
just received the 2nd knurled nut, in the mail, have to wire wheel that piece
motor gonna take a bit of work,
there was aton of old mud dauber nest in the housing of the motor, got most of it cleaned out.
wiring was shot, so i jerry-rigged it, just to see if the motor would run or not, and ill be darn ran smooth and quiet as can be.
but i wont be able to mount the motor back on the motor frame because all of the rubber motor mounts all completely shot and turned to goo. so ill have to improvise something for that.
if i get the chance to tomorrow, ill try and post some pics.
G
gilbo
here a few before and after pics, and some pics of the motor tear down
i removed the badge from the head and guard (aka helmet) before electrolysis and painting
i used wire to plug the holes before i painted
All the pieces are still taped up
Motor tear down pics
I was able to get the nameplate off the housing by punching it out from the back
endbell from the wire side of the motor, outside and inside, as you can see just under the tag, there a oil hole cap to lubricate the sleeve bearing
These pics are from each endbell that are yarn packed to lubicate the sleeve bearing with oil
fins are in ok shape
centrifugal switch looks ok
armature in ok shape
i forgot to take a picture of what the inside looked like with all the mud dauber nest, here a pics of someone else's motor i found on the net, this is basically what mine looked like before the clean up
Here are two pics of after the quick cleanup, gonna clean up some more when i get the chance
well that's all for now
G
gilbo
alittle progress well sort of
well just incase i have issue coming up with a suitable replacement motor mounts on the jack & heintz.
i picked up what i belive is NOS Dunlap motor as a fallback, paid $65 for it, might be touch high but, i kid you not this motor is in pristine condition, not even a mark on the shaft, the cord is still wrapped like from the factory and it came with papers
here are few pics of it
zkling
Great job on the motor. Can't wait to see the completed pics. :thumbup:
Rust
The Path of Least Resistance
The press is turning out very nice.
And that motor find was very cool. That thing is cherry.
But the Jack and heintz 1/3 hp capacitor start motor may have a little more torque than the 1/4 hp split phase.
Either way is a win for light duty drilling.
G
gilbo
That's a cool drill press. Nice work so far on the resto.
And that motor is nice!
thanks a bunch folks, just wish there was more hours in the day, to have some time to work on it more, if i could just squeeze out abt 6 more hours in a day, that would help
yea i think the backup motor was a good p/u, but still wanna try get jack & heintz restored back to its glory days (atleast somewhat close)
