D45
I would like to get my gas fireplace up and running
Bought and moved into the house about 3 years ago, used it 3 times because it was a PITA to get working
From my view, it looks like a wood burning fireplace that was converted into a NG fireplace
The flue opens and closed fine, so vents is not an issue
In my old house, which was MUCH newer and NICER, I just let to gas run on the pilot year round and then flipped a switch on the wall for flames
I am not sure I want or need a complete new insert, but maybe I can be talked into it also.......
The current fireplace is set into the wall corner, so the inside is oddly shaped, not a rectangle and not a V
I cannot get a spark to light the gas
Bad ignition or what?
I took it all apart......is this pressure activated or should there be a battery on there for spark?
Pretty similar to a gas grill....right?
When I push the ignition button it doesn't pop
