I'd like to build or buy a welding table. How does one go about getting the right sized top? I don't have a plasma cutter or anything like that so what is the normal way to go about getting a clean cut sheet?
New to the metal working.
A really cheap way is with an abrasive blade on a Skilsaw.
Exactly. The easy way is to just buy what you need. If it's 1/4" or less, you can cut it pretty easily with a $20 steel-cutting blade and a circular saw.
Video of what I mean
With a jigsaw, it's not going to be easy to cut a clean, straight line.
Much thicker than that and you're going to want to have a steel supplier or shop cut it for you.
My local metal supplier charges $7.50 per cut to shear plate. For this amount of money it"s not worth it to me to burn it and then grind it smooth. If you are buying new material try to make you bench 4' x whatever, 4' is the standard width for plate so you will only have to pay for one cut. FYI <1/4" is sheet 1/4" and above is plate.
