metaleltr
I prefer to start from the end on 25, 50ft cords
Definitively doing this method on the 100s now!
I've done a little looking locally and it has me wondering about them. The 12/3 cords I saw were all rated for 15A but I thought the 12 gauge cord could handle more so does that rating result of the ends used?
Woods are made in USA.
It's most likely due to the use of 15A ends. A 12 gauge extension cord is good for 20A loads but can only be rated as such with the proper 20A ends.
Take a look here, lots of good information:
http://home.mchsi.com/~gweidner/extension-cords.pdf
What does the "E" in a SJEOW cord stand for? It's not in the list provided earlier. Is this a sneaky/alternative way to get a "T" in there? Here is a link to such a cord: colman polar solar
The Rigid one's in Home Depot are pretty good (I've got a couple I use for the saws and whatnot). Illuminated end, 12 ga. and the cord is pretty flexible. If you coil it up properly (yes, there is a right way), you should be fine.
Thanks for the link… I figured the rating was affected by the ends. One of my tools uses over 15A and I was wondering if those 12/3 cords would be fine or do I need to change out the ends?
