Nicked neutrals what to do
machsnell
Northern Virginia
I nicked both neutral wires and jackets in 2 lines cutting a hole for mini split lines.
It doesn't look like any strands were cut through upon initial inspection.
I will assume the safe answer is to remove wires and re wire or take to a jb somewhere in line.
How much current does the neutral ever carry?
If I can open up a little and more closely inspect. Is it remotely possible to tape neutral well and the tape cut jacketed area?
Sent from my SM-G960U using Tapatalk
MrSurly
East Texas
The most important indication is that you can't even SEE how much damage has occurred until you remove the cable....and if you remove it to inspect, clearly you are not going to perform any kind of "repair" and reinstall this so, yes, automatically this must be replaced.
Showkey
"MEMBER EMERITUS"
Wausau WI
Depending on where they go and access.........replacing the wires could be a real adventure !
walta
Dutzow Missouri
An acceptable repair would be to cut out the damaged section of wire install 2 boxes with new cables between them.
Note the boxes cannot be buried in the wall so you must have 2 cover plates exposed on your walls surface.
Walta
mike93lx
Richmond, VA
Walta
NM splices are available that can be left inside the wall.
I would try to bypass or remove the bad section and replace or splice it somewhere better though
walta
Dutzow Missouri
You should be safe painting on several coats of liquid electrical tape, it really doesn't look too bad.
Could the damaged wires be taped up make it work, I am sure it could but I doubt that tape wrapping would qualify as a code approved repair. Years later someone would find the tape and ask what hack wired this place, I had better check every connection.
Walta
walta
Dutzow Missouri
I personally am not 100% comfortable with buried connections code approved or not.
I do admit it look like a tempting option if it were my wall.
Walta
Corndoggeh
I wouldnt even question myself to replace or not. Bite the bullet and replace. Either using a junction box type repair where you cut out the damaged section or replace the full line. Then count your blessings the saw didnt cut into the hot.
Makes no difference. The neutral can bite just as hard...
Lassen Forge
Holy Moley... that's one heck of a "nick". Hate to tell you this but yeah, that's going to have to be pulled out and re-run with new - no way I'd trust that. Use the old wire to run a fish tape, then pull new romex behind it. And yeah, be glad you didn't hit BOTH the black and white at the same time.
rharman
SoCal
^^ Ditto what she said.... ^^
nsula_country
Northwestern Louisiana
May have. Check teeth on holesaw.
CT
