Nick's Garage
NFS_87
Chesterland, Ohio
Hi All,
My fiancee and I recently purchased our first house, and I figured I would show off the garage and the future work that will go into making it a combination wood and metal shop. It's with an addition on the back that houses on one side the 1924 South Bend engine lathe that came with the house (that didn't influence my decision to like the house at all. :lol: ) on one side and in the other side the old Craftsman 10" table saw and jig saw that also came with the house.
We're still working on moving in and I have to find spots for my current list of tools. The plan at the moment is to use the room with the lathe as a metal working area, the room with the table saw as a wood working room with cabinets and yet-to-be purchased tools on casters to move them into and out of the way while using them (this is the smallest area in the garage but has a garage door on the side. The main garage will be used as a work shop for assembly of any projects as well as an area to work on my 1966 Jeep Wagoneer and a place for my fiancee to park during the winter (until -read, IF- I can convince her otherwise).
I think using the main garage as an assembly area for projects will keep the saw dust and metal chips down in that area and will make for a good 'clean' room, while the saw dust and metal chips can be contained in their respective rooms in the back.
I am definitely open to suggestions from the more experienced here and am looking forward to getting this project underway so I have a place to unwind after a day at work (manufacturing engineer at a sheet-metal fab shop).
Right side of main garage:
Left-rear side of main garage:
Left-front side of garage:
Looking through the door in the back into the lathe room (lathe runs on a line-shaft on the ceiling):
Lathe Line Shaft:
1924 South Bend, 15" swing x 8' bed:
Looking at the lathe room from the woodworking room:
Left side of the wood working room:
Right side of the wood working room:
-Nick
zkling
Holy ****, line shaft and all. What are the dimensions of each room?
N
NFS_87
Chesterland, Ohio
Thanks!! I couldn't believe it when I walked into the back of the garage and saw the lathe. We couldn't get into the garage the first day we looked at the house either, so I didn't even know it was there until we went back for a second look.
The main garage is 22 x 24, the addition is 10' more, so the room with the lathe is around 10 x 12 and the room with the table saw is around 10 foot square. Not a whole lot of room for completely building woodworking projects, but I want it just to keep the bulk of the sawdust out of the rest of the garage which I can use for assembly. Woodworking is more of a 'lesser' hobby for me compared to metalworking, but I do plan on making a lot of wood projects for the house, so I'm sure I will run out of room pretty quickly in all areas!
