metal1313
So this is specifically for new jersey residential work, namely my own home in hunterdon county. We are finally getting natural gas run up our road, the main literally circles our street, and stops 300’ away. In preparation for this, coming this fall, I’m working on my plan of attack to run gas lines from one side of the house where the meter will go, to the other. I have a fully finished basement, so it’s not easy to just run it there. I can go up and over, single story ranch with unfinished not useable attic. The total run would be under 60’, including rise and fall. Since this is just for the stove, would 1/2 lines be sufficient or should I go 3/4? Also debating if I should use pipe, or csst flex line. The flex line would be easier to run, less joints and just faster, but I have threaded miles of black pipe, however I no longer own threading tools so I have to source those, adding to the expense.
right now I’m going to convert the stove and dryer back to ng from propane, very easy for me to do, newer appliances and I have the original jets. Then eventually a new furnace(oil forced air) and new water heater. I have to figure out if our existing chimney can be used, or if I can go power vent for the water heater, window locations and such and not too up on codes anymore espicially here
