1/2 Cup
Member Emeritus
njhoudini doing real well now
njhoudini doing real well now![]()
Glad to see you back again NJ. Was wondering what happened to you. Good luck as you prepare for the new family member.
Bret
Congratulations on the new job!
I never did well in a cubicle. It was always a good incentive to look for a new job. I sympathize for people for whom it is a necessity.
Welcome back
Good to see you in.
And congrats with the new job.
Eugene, congratulations to you and your wife! You have some excellent People-Making skills.![]()
Congratulations
njhoudini
Congratulations
Congratulations NJ!
Congratulations!!
And. about the window that's leaking, it's, ummm, open.
Garden bed
Kids eating fruit
Good to see you back.
Howdy everyone!
It was a busy week.
Celebrated another trip around the sun and my coworkers decided to dress up my office. Huge fan of the team I get to work with.
Saturday, SWMBO went with the kids to visit the in-laws so I had the entire day to work on some projects.
On my way back from an unsuccessful trip to the bank where "their network was down", I happened upon a garage sale and picked up this backpack blower for $20. It runs only on full choke so I imagine that something is clogged inside the tiny carb.
I also got a call back from someone who was selling a 1950's ShopSmith. A little skeptical, I went there and decided it was coming home with me. We agreed to a price of $100 which if I'm unable to get it going will easily be recovered if I decide to part out the machine. It took quite a bit of thinking to figure out how to get it out of my trunk.
Here is the main body.
It also came with the table saw table, extension table, mitre gauge, and the saw blade arbor. It is missing a few items which would make it look like this.
I'm positive I can make the stand, and can probably make the piece that supports the two main poles when the ShopSmith is lying down. At worst case, I have a functional lathe since I know that the motor does run. The only main issue for using the lathe may be that one of the 3-step pulleys looks like it was in the wrong place at the wrong time and a section is ground away missing.
Parts are surprisingly available via ebay so if I can't diy a part replacement, I have options. Very chuffed with both the blower and the multi-function power tool as Rian might say!
I also rearranged some of the stuff in the garage, picked up some more plants for the raised bed garden (sorry, no photo), and finally remembered to put my new replacement tire on my car and put the spare away in the boot. Oh, I also replaced my cabin air filter. From the looks of it, it hadn't been done possibly ever.![]()
The garage floor is somewhat visible again and I'm looking forward to getting in there hopefully a dozen more times before winter.
Hope everyone had a nice weekend!
I went to AutoZone to go get a metric impact socket set and the employee talked me out of it and to pick up a thin walled "lug" socket. It didn't work. The socket failed and tore at one of the thin seams. One of the chrome caps is now spinning and the other 3 on the same tire have swollen caps. The lock nut is fine. I picked up new lugs to replace the swollen ones. Now I'm going to have to go to Harbor Freight to pick up a set of cold chisels to assist in removal of the bad chrome caps as well as a set of metric impact sockets.
are deep impact sockets better for lug removal than regular impact sockets? The lugs aren't very long and they have a rim by the washer. Having seen videos on how to remove chrome caps from these lugs, I'm confident I can get the cap(s) off, but I'm praying that the actual lugs aren't stripped or severely rounded over. PepBoys has really screwed me this time. Questioning if I'm ever going to let them touch tires on any of my cars. This is very inconvenient, but I may end up having to pick up jack stands while I'm at HF so I can rotate my own tires. Very annoyed, very exhausted, and annoyed at the recent string of events.
Eugene, you deserve a double You ****, along with a Well Done. The plane and Shopsmith earned the You ***** and teaching your wife what to look for at garage sales earns a Well Done!I proceeded to try to remove the tire with the hole but discovered that PepBoys decided to super torque the lugs.I went to AutoZone to go get a metric impact socket set and the employee talked me out of it and to pick up a thin walled "lug" socket. It didn't work. The socket failed and tore at one of the thin seams. One of the chrome caps is now spinning and the other 3 on the same tire have swollen caps. The lock nut is fine. I picked up new lugs to replace the swollen ones. Now I'm going to have to go to Harbor Freight to pick up a set of cold chisels to assist in removal of the bad chrome caps as well as a set of metric impact sockets.
Question,are deep impact sockets better for lug removal than regular impact sockets? The lugs aren't very long and they have a rim by the washer. Having seen videos on how to remove chrome caps from these lugs, I'm confident I can get the cap(s) off, but I'm praying that the actual lugs aren't stripped or severely rounded over. PepBoys has really screwed me this time. Questioning if I'm ever going to let them touch tires on any of my cars. This is very inconvenient, but I may end up having to pick up jack stands while I'm at HF so I can rotate my own tires. Very annoyed, very exhausted, and annoyed at the recent string of events.
Your socket question is more complicated than deep or shallow.
I'm sure there are lots of uses for short impact sockets (the first set I bought back in the 1960s were short) but I always pull a deep socket now. An example might help. Here are four different depth sockets on a wheel. The three lower sockets in the photo are deep but because the third from the bottom is a 3/8" drive, it isn't as deep. I don't own a shallow 22mm impact socket so the upper one is a shallow thin-wall socket. It requires an extension to prevent tearing up the rim. Not really a problem using an impact gun but it's a consideration if you are using a breaker bar.
To me, the number of points on the socket are more important than the depth. If you buy a set of Pittsburgh (Harbor Freight) sockets, avoid the 12-point sockets like the ones I bought a few years ago. A 6-point socket is less likely to tear up a lug nut. I recently bought a set of GearWrench 3/8" drive deep sockets for close to a Harbor Freight price. I don't think it is a big problem now but the SK impact sockets I purchased in the '60s have super thick walls and very shallow engagement depth. That 13/16 socket (upper right) won't fit in the holes on the rims on the Corvette. The green socket (lower left) is a gimmick, with a nylon sleeve to prevent marring the hole in the rim.
(still amazed by the process of making the hole bigger for the plug
, but I digress).
I'm excited to see you get the 2 shop smiths up and running. Glad you got the lug nut off.
Bret
The “like” button is an easy way around for lazy people.
But just wanted to say that I like your progress and updates.
@Bret of course we know you can never have enough machines.
I didn't open it prior to sending it out, but if Dewalt refuses to provide free service, I'm probably going to open the motor and see if I can coat the magnet(s) with a thin coat of polyurethane and squeeze out a few more years from it.
Glad to see you back Eugene. Looks like you have been busy!
Bret
Great job on the step stool.
Those Shop Smith’s are great tools. A local woodworker close to me has a huge wood shop set up with some very expensive tools, but he also has his Shop Smith set up. He tells all new woodworkers that they should get one.
Eugene, nice job on the Shop Smith. The step-stool is a nice looking piece and I suspect you'll get requests for more. It's amazing how fast a flat surface fills up. I agree that you need a taller bench to work at. My back is complaining just looking at that coffee table.
