NM-B Wire Installation?
Beamer
Northeast
Can an NM-B (AWG 6 cu 3 w.AWG 10 ground) wire be installed on the bottoms of floor joists above the unfinished basement traversing the joist spaces?
Can the routing be at an angle (not perpendicular) to the joists so the contact points are greater than 16".
What is the fastening spacing requirement?
dave*99
Coastal NJ
Edited in recognition of post 12.
I ran 6/3 Romex On the bottom of floor joists along the block foundation. It was neat and protected. Tucked it just above the block wall near the sill plate.
reader2580
Minneapolis, MN
Do you not want to drill holes in the joists? That is what I have done in joists when wiring my house. I just make sure to stay the required distance from the edges of the joists.
Beamer
Northeast
That's a pretty stiff and long snake to be wrestling with for what may be an 80 foot run so that would be a pretty tough undertaking.
Some searches seem to indicate a relaxed requirement for heavy wires but I don't trust search results since the computers were put in charge, so the posting here.
I am also curious what method of splicing the three #6 wires, as well as the ground, would be good.
Beamer
Northeast
no.
either drill holes thru the joists or run on top with rat runners.
What do you mean "run on top with rat runners"?
I am not understanding but do you mean run support boards at bottoms of joists and wire under those?
Is there a different requirement for heavy wires like the 6-3+ wires of interest?
dave*99
Coastal NJ
You could get more informed answers from the forum if you describe the whole project. Yes it can be spliced. But maybe there is a clean solution without splices.
What are you installing?
Beamer
Northeast
Retrofit upgrade wire from main panel in the existing basement (under floor above) to a secondary panel at an addition.
Splice is definitely needed for wire material on hand.
Curious about the code intention regarding protection from damage. In an unfinished space, it seems that running through joists or under joists both may be at risk of someone hanging something from the wire in an exposed condition.
Is there a different kind of damage of concern?
dave*99
Coastal NJ
Retrofit upgrade wire from main panel in the existing basement to a secondary panel at an addition.
Splice is definitely needed for materials on hand.
3 splice options come to mind. Wire nuts, split bolts and Polaris connectors.
Beamer
Northeast
I looked a bit at Polaris connectors. Would that require three separate connectors, one for each power line, or four to include the ground?
"rat runners" aka running boards are strips of wood run along the top of joists that you staple the NM-b on top of. they go on top of the joist not underneath for small conductor cables smaller than what is listed below.
NEC code 334.15(c) allows cables larger than 2 #6 or 3 #8 to be ran on the underside of the joist
Beamer
Northeast
There is confusion in the "rat runners" description given but the Code reference section diagram shows what I understand.
The runners are shown on the bottoms of joists for the smaller wires only and that is what is applicable.
Thanks for the Code reference.
mm08822
Since your cable is larger than 2 #6 or 3 #8 it can be run on the underside of the joists w/o runner boards or adjacent nailers. Must be secured at intervals no more than 4.5' and no more than 12" at box entries. I would go tighter than 4.5', maybe every other joist. It depends how well it follows the joist contour......could be every joist to be neat.
Beamer
Northeast
Also helpful.
The last piece of that detail is whether the angle of the cable to the joists is restricted to 90 degrees.
Diagonal layout would economize on amount of cable and there is no question that the attachments can be smaller than 4.5 feet.
manwithtools
Lebanon, TN
Some terminology confusion here, OP is talking about wire being under "Floor" joists. "Rat Runners" as you pointed out go on top of joists, specifically "ceiling" joists. So one is under the floor and the other is above the ceiling. In anycase, it appears code has him covered in this application with no additional support structure required.
