acs118
No Rinse Concrete Etch ¿/ Rust Bullet Duragrade No Prep
Hey all - question about concrete floor prep: Not for my garage but for my basement (bike shop/ man cave). The floor is currently an old, bare concrete slab. I have filled in any cracks with an epoxy crack sealant and ground it down flush. I also cleaned the floor with an industrial cleaning machine after it got dirty during some drainage work. Because of the age of the house/ foundation (100 years) and current cracks I expect some minor movement will continue to occur so I'm steering away from an epoxy finish due to cracking. I'm pretty set on this poly blend paint from Rust Bullet called Duragrade Concrete. Expensive but I'll willing to pay for a good finish that will last awhile. Again, this is in my unfinished basement so need to worry about hot tire pick up, extreme temperature swings, etc. The paint claims it doesn't require as much prep work as is typical with concrete coatings (acid etch/ grind/ etc). I'd still like to do some prep however the usual etching and rinse, rinse, rinse isn't really an option inside the house so I found this 'No-rinse Concrete Etch' : No-Rinse Concrete Etch from MasonrySaver .com Anyone have any experience with no rinse acid etch or input on the prep work needed. Also welcoming any input on other coating materials too.
Edit: Does anyone have experience using Duragrade Concrete without etching?
TLDR; Interested in trying a no-rinse acid etch prior to coating basement concrete floor with poly blend paint.
