kmacht
So I am getting around to all the maintence at the house I put off when building the garage and one of the projects for this year was to replace a 2nd story window. The windows are original to the house so the sill was rotted out and they were pretty inefficient. It was time to pull it out down to the window frame and put in a new construction window with nailing flanges. I have done this in the past on the house and never had a problem. This time I ran into one and need some advice. When I pulled the window out there was obvious signs of water damage with a bunch of rot on the frame and the wood sheathing that will need to be replaced. The problem I am running into though is that there is no tar paper over the sheathing. It is all over the rest of the house between the sheating and the wood shingle siding. For some reason there isn't any on this side. The water looks like it got behind the metal flashing on top of the window and just ran down both sides rotting out the wood sheating the whole way down. I would rather not tear all the siding off just to put tar paper up but I am confused on how to flash the window without it. Normally I would slip the top and sides of the window behind the tar paper so that any water running down behind the shingles didn't get behind the nailing flange. Has anyone run into this before? How do you seal off the nailing flange and what do you do about the metal drip edge up top. That seems ripe for letting water behind it if it isn't covered with tar paper. Looking for some advice.
Keith
Keith
