ilya
I live in an older apartment and I would like to replace a 2-prong receptacle in one of the outlets with a grounded 3-prong receptacle. The outlet box is grounded via armored BX cable (after connecting a multimeter between the outlet box and the hot cable I see 120V).
The problem is that the outlet box does not have a threaded hole for attaching a grounding wire. What is a code-compliant way of grounding the receptacle in such case? Is it possible to drill and tap a hole for the grounding screw?
Thanks!
Thanks!
