Nohr-S w/ Metallic Color?
arthurk192
San Jose, CA
I plan on calling Legacy Industrial tomorrow but wanted to check with the community. Has anyone tried mixing the Metallic color pigment with Nohr-S? I'm assuming its a no-go but before giving up I wanted to check since that would make for a really cool design that is more durable than epoxy.
A
arthurk192
San Jose, CA
:( as expected it won't work. You need to use Nohr pigment for Nohr product...hopefully one day for a future garage more color options will be available
Initial phone support is just a call center to take your messages but the actual support form the company is so far awesome.
LegacyIndustrial
deerfield, IL
Yes we did speak. In theory it works. However, the material dries so fast it would leave you with roller marks and start/stops everywhere.
The beauty of the metallic additive is best suited for our Metallic Epoxy, it's thick and lustrous, allows 35-40 minutes of working time which also allows the additive to flow freely through the resin. It is quite something to watch occur.
You can add glitter to your Nohr- Clear Coat and roll out, we have had customers do this successfully with Polyaspartic, dry time is similar.
LegacyIndustrial
deerfield, IL
