Non-conductive, non-flammable busbar mounting board
bluedog225
Texas
I want to mount a couple of Victron Lynx busbars on top of my server rack battery racks. Part of my off-grid solar project. Per the title, I’m looking for a good mounting surface. A 2x6 would work fine but I’d prefer non-flammable.
I’ve got some scrap corian countertop but I don’t know the grade and don’t think it would do well when exposed to flame. I may go ahead and spend the money on glass reinforced polyester laminate (GPO-3). They sell “scraps” on eBay. But thought I’d check in here for other suggestions first.
Whatever I choose needs to have some structural integrity.
One other idea I had is to paint a 2x6 with intumescent paint. Wish that stuff were cheaper.
Thanks
mm08822
Look up the specs for FRP. - conductivity. Also need to make sure dirt, dust, moisture can't accumulate and cause leakage. Distance between terminals is very helpful.
Covering the busbars with shrink wrap will add additional safety.
PCustoms
VT
I googled the busbar, aren't these fully enclosed in a plastic case?
bluedog225
Texas
Yes. I’m interested in keeping the fuel load down in the area of the batteries, inverters, and charge controllers.
Firebrick43
West central Indiana
This is the stuff you want. Would be a good idea to mount five or six stand-offs, 4 in the corners and one or two in the middle and use an 1/8 piece of garolite to shied the top that can easily be removed with a few thumbs screws. It works easy with wood working tools. Just about all the industrial equipment I worked on used it to mount the main bus bars and fuses to inside the electrical cabinets.
KenC
oklahoma
I once owned an old building, original electrical equipment circa 1916 was a panel with copper bolts/studs and knife switches, no overcurrent protection. All mounted a slate backing, about 16x24 and a little of an inch thick. There were no receptacles at all, just a lot of lighting.
I thought that slab of rock was really unique and wanted to save it for display, but dropped it. Shattered in a million pieces.
Kinda hard to find, but surely fireproof!
