Non marking vise jaws. what to use?
WhyMe
my vise has serrated jaws. I wish to use it for adjusting and installing pistol sights. Of course i prefer the slide not to have teeth marks on them, so what does GJ recommend for non marking jaws?
Davefr
OR
These:
Lowes stocks them.
zkling
I use a variety of things. Mostly rubber that I salvaged from things I found in the trash. My favorite is a piece of 1/4" thick orange rubber stripping that came off the edge of a floor buffing machine. They have a lip on top and fit perfectly on my small vise jaws. They are soft enough to not marr the work, but just firm enough to keep the work piece in place.
I can get a pic if you want.
thundermug
usa
If you've got some old garden hose laying around, slice it up the side. It may be large enough to fit over the jaws. Or try old bike tire. Quick and dirty.
Vvmvbb
CT
Do you have any aluminum L stock lying around by any chance?
Or you might be able to get some oak L stock at HD.
ken w.
Western New York
I use leather vise pads I got from Brownell's . It's basically a piece of thick leather that you that you bend in between the 2 jaws. Smooth vise jaws will also leave a mark on your gun. You should always use a softer pad.
larry_g
oregon
Vise Jaws
The link above is to a MSC catalog page. That page and the next show some different styles available. The copper ones you can make out of a section of copper pipe. The canvas, leather, and wood ones you can also make.
lg
no neat sig line
Ed ke6bnl
Agua Dulce, Calif.
what is really nice if you have a good size chunk of al. and a mill is to put the al jaws on the vice and close it and run a rabbit type cut in the al. to hold parts for drilling.
rlitman
Long Island
I have a set of copper jaws for my big vise. I have a smaller vise with dedicated aluminum jaws. I have sheets of lead put aside for gripping threaded parts (I'll use aluminum with threaded steel most of the time, unless I need to crank down on the handle).
But I wouldn't touch a gun slide with anything other than rubber, leather, those plastic jaws, or my woodworking vise with wood jaws (hint hint).
This ^^^ and the bolded part of this VVVV
For threaded parts with external threads, I've started cutting a nut on one side on the point and threading it on and gripping on that. After a while you have it for all threads...
ps: I also use lead jaw covers, but not on finished gun parts, internal non exposed, is OK.
rlitman
Long Island
Hey, I like that one. I may need to set aside an assortment of square nuts I have sitting around for this.
Yeah, lead will leave silver marks on bluing.
Well, if you use square then don't do the cut on the points, I'm using hex huts. :beer:
EOC_Jason
Bentonville, AR
My friend whom is a riflesmith uses these from Brownells. You have to notch it for your vise slide. He uses them on a daily basis and even after several years they still look practically new. He's gripping tapered barrels and odd shaped receivers all day long.
theknurl
SoCal
semi truck mud flaps make great rubber soft jaws also the 1/4" Birch plywood just cut them to fit the slide
:beer:
