Non-Permanent canopy 'flooring'
coderedpl
Long Island, NY
Hello everyone,
I recently moved into a rental property that unfortunately does not have a garage but has a decent amount of backyard space and a driveway, so with that I ended up scoring a deal on a lightly used Costco 10 x 20 canopy with sidewalls. Primary purpose of being able to wash car in shade, detailing, and just general work on the vehicle to keep me out of the sun and whatnot.
I have it sitting on bare grass now, but I'd like to add some sort of a 'floor' I guess you can say to keep things less messy and to be able to use the jack and jack stands when I need them. I thought about just buying some generic plywood, maybe some 2x4 to even it out.
My biggest "concern" per-se is, to make sure, I'm staying on the low side of spending $$$ as it is NOT my place, it is NOT permanent and will not be to a crazy extent.
In regards to washing car the only downside I'd really have is wet grass under me (until it dies), when it comes to lifting car, in the end, i can get a bigger section of wood and just put jack under that (same for jack stands)
I saw someone do something similar somewhere around the forum, but seems like it might add up to more than i'd like. So far my cost is below 100 for the canopy :bounce:
Garage Flooring
Grand Junction, CO
Hello everyone,
Portable.... but not cheap
https://www.garageflooringllc.com/fastdeck-portable-event-flooring/
alwaysFlOoReD
Airdrie, Alberta, Canada
I lucked out and found some used 4x8 sheets of concrete form plywood. I'm pretty sure they oil these so the concrete doesn't stick, so I think they will work for me doing the same idea as you. I also have some 1" foil backed polyiso insulation I'm going to put under it.
C
coderedpl
Long Island, NY
Do you guys think plywood is a bad idea?
Putting a few sheets just to have in place for a ground of sort? I'd strap then together with joints of some sort and keep laid out
Sent from my SM-G960U using Tapatalk
alwaysFlOoReD
As a semi-permanent idea I think its fine. The problem would be moisture fromt the ground coming up and causing eventual rot. This is why I would use PT or oiled wood. my thought for the insulation is twofold- a barrier for moisture and a way of helping when I heat in the winter.
No experience yet....
C
coderedpl
Long Island, NY
Is it OK to kill the owners grass?
Bill
He has dead spots and "bare" run-down spots here so I'm not too worried about it dying out or whatever. Lease is signed for 2 years so when it gets closer to move out date, I'll have time to "fix"it
