beeph
I cut off my fuel vapor vent hose on my gas tank, but the hose clamp is stuck on the vent ******, with bits of hose wedging the clamp stuck to the ******. I cant pull the clamp off, and I have very little space to work with as it is almost butting up against the frame of the car.
Normally I would take an angle grinder with a metal cutting disc, to cut the metal band, but it will cause a lot of sparks which would be very dangerous around my gas tank.
Is there a spark-less tool I could use to saw the hose clamp off? The more compact the better, have very little space to maneuver.
Wipe down and oil tool after done.
