I am contemplating build an enclosed trailer and trying to cost out materials. The goal is to keep the price "reasonable" and the weight low.
Most enclosed trailer use 3/4" T&G plywood for flooring, just like houses. The problem is, they will be subject to moisture from below and possibly above if the roof leaks. Moisture causes wood to rot. Replacing a floor in an enclosed trailer likely means disassembling any interior and the walls.
Something like the 5/4 PT deck boards is an idea, but 1) they are very heavy (more than 3/4" plywood) and sealing inbetween to prevent road splash is going to be almost impossible.
Aluminum planking is too expensive.
I am considering making a joist system out of 2" 0.125 wall aluminum square tube, adding bracing between the joists and 2" rigid foam between these members. Finally cover the whole thing with fiberglass. Lots of work, not cheap (3-5 layers of glass ?) and of course you really need to do both sides ! How about gluing down some kind of rolled aluminum ?
Azdel (a synthetic panel used in RV sidewalls) is interesting, but it is typically only 1/8" thick and not available to "consumers".
Any other ideas ?
Any other ideas ?
